Re: Mold/mildew buildup on exterior. How to stop and remove
There are a few different mildew preventers that could be worth trying after you get the existing stuff removed.
3M makes a product that works although it isn't a true 'mildewcide' like others...but works in different ways to stop it from adhearing.
But yes with how oxidized and textured that finish is it stays wet longer...and gives lots of surface area for stuff to live. Get it smooth...and problem solved! See recent thread about sanding, polishing, and waxing - the pictures might motivate you.
not in the water since you got it?!?! poor girl! maybe a little lake/ocean water will cure the problem too
Also maybe spin the boat once in a while to get different sun exposure to dry out boat on all surfaces (especially during wet periods of teh year)
