Re: Cooling your Cuddy Cabin
... Wonder how much energy the pump would consume if the draw was equal to the return?
If the water supply and returns are both below water level, the net pumping height is zero.
You would only have to overcome the friction of the lines.
It could use a small sump pump to move it.
A few hundred gallons an hour would be a lot of heat capacity.
There is a reason that air conditioning units are rated in TONS.
A very small 1/2 ton a/c unit (6000 BTU) is equal to 1000 lbs of ice per day.
That is a little over 40 lbs of ice per hour.
You can cool with ice and a fan but be ready to add another 20 lb bag of ice every 30 minutes.
Freezing cold water is not the same as Ice.
It take 80 time"s more "Heat" to melt a pound of ice as it does to heat a pound of water one degree.
That is why icebergs last for months and can travel thousands of miles.
