Re: 2503 CC aft bilge pump replacement--I need longer and thinner arms!!
Great idea....but...how did you get the cartridge out to begin with? I was thinking of using one of the extended grabber things that assist the disabled with reaching things on shelves, but I didn't think I would be able to get the pincers to sit on the tabs squarely enough to get the cartridge out.
This is one of the few inconveniences on an otherwise great, user friendly boat with a lot of creature comforts?
The pump works fine manually, but the automatic switch doesn't. I am the type where everything has to work perfectly or else i go crazy.
Thank you very much for your input.
