I am in need of some help with my 2000 Johnson 60 hp fuel primer. I will not start unless you turn the red lever on the primer. I don,t see or hear any activity when the key is pushed in to prime. I tried to start it today and it would not start even with truning the red lever then it is getting a little gas with the primer hose disconnected after a few hours fishing using the trolling motor I decided to try to start again it started up with a lot of whiteist, bluish smoke then cleared up. After I got home I hooked up the hose and it started right up. I still dind't hear or see any monement of the fuel primer. How can I check this out so I won't have this no starting next time I go out on the river. Any help is appreciated. Thanks.
