parrothead_nj
- Apr 28, 2012
- 6
Our freshwater system was working last week, and this morning when I turned the faucet worked, then trickled out and then sputtered as if the tank was empty. The tank sounds empty, but I can still see water in the fill tube as if it were a full tank. I ran a fishtape down the supply line and the water didn't move. I tested the pump with a bucket of water to make sure it wasn't the issue, and the pump sucked the bucket dry.
Is it possible that the intake could be clogged? It is a 1 1/2" tube. When I go back to the boat tomorrow, I am going to remove the supply line and blow some air into it to make sure its not clogged at the exit.
Thanks,
Kevin
Thanks,
Kevin
