Hi guys, I have just changed my steering helm from a Morse D280 to a Ultraflex T71FC, I was lead to believe the cables would be compatible, manufacturers comments, however I cannot get the existing cable end fitting sufficiently in to engage the lock bolt, I was thinking of cutting 1.5mm of the end fitting to enable full engagement, any thoughts on this and are the inner cables compatible, the fitted cable has no manufactures marks but it does have a red stripe along its length.
