SDSeville
- Mar 19, 2010
- 1,481
OK. I had some bad rust and exhaust stains on the hull, so I tried the miracle cleaner - Lysol toilet bowl cleaner (blue. no bleach). Applied with a sponge, let it sit 10 minutes, hosed off -- maybe removed 20% of the crud. Applied it again and scrubbed with the other side (abrasive) of the sponge -- nothing. Mixed 50/50 with peroxide, sponged on, scrubbed -- still nothing.
I will say that id did remove a rust stain I had not been able to remove. However, there are still a lot of black exhaust stains that were not touched. What did I do wrong?
By the way -- I have been a Vaseline guy for the past couple years and this stuff did remove every last bit of Vaseline I ever applied. It is now the same horrible pink (rather than red) chalky color it was before I started my biannual Vaseline treatments. So for those of you who were worried about the irreversible effects of Vaseline, worry no more.
