Re: Dock on river, no shore power, bilge?
I have a 16.5' open boat with no cover and routinely go 2 weeks in rainy weather with a GOOD battery using 2 bilge pumps with 2 float switches. Either switch will activate the pumps.
I don't have any leaks and the pointy end is facing the waves, so it's just rain I have to deal with.
agreed. My family has kept boats in the water with no power for decades; single battery, float switch (or sometimes a chlorox bottle bailer).
The float is designed (or should be set) so the boat accumulates a safe amount of water before it kicks on, to preserve battery. Keep in mind that heat wears out a battery, too.
Forget the solar and the weight of extra batteries can cancel the benefit (at this point, a lot depends on the size and design of the boat, how far away you are from the boat and how long it would go unattended). If you are going to get a storm that dumps 10" in 2 days you should pull the boat out.
