JoLin
- Aug 18, 2007
- 5,146
I have the shower sump box apart awaiting a new float switch. While I'm at it I'd like to replace the old corroded drain fitting inside the shower. Anyone know how these come off, and where to find a replacement? I've googled and can't seem to find that part anywhere. The drain hose from the fitting into the sump box pump is 3/4" I.D.
Any help appreciated.
(btw, being new to the boat last year and never using an on-board shower before, I was unaware that the float switch had failed. I apparently spent at least part (maybe all) of last summer flooding the box and having it flow out into the forward bilge. I just scooped 16 gallons of water out of there with a plastic cup. :facepalm
