Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
U-Shaped Bimini Mounting Bracket???
This topic is closed.
  • U-Shaped Bimini Mounting Bracket???
    I am looking for a set of white nylon u-shaped brackets for my bimini. Fits on the windshield of a Maxum 2300SC Runabout. Any help locating would be appreciated.
    Thanks,
    Click image for larger version
ID:	133130Click image for larger version
    Re: U-Shaped Bimini Mounting Bracket???
    Hello and welcome to iBoats! Have you tried searching on eBay?
    Boat: 2011 Tahoe Q7i
    4.3 MPI 220hp V6 Alpha 1 (1.62 gearing)
    20p Mercury Enertia X7 Alloy 3 blade (AWESOME)
    Vehicle: 2013 F150 Platinum Tuxedo black, 3.5L Twin Turbo V6, 3.73 gears.
    • #3
      I have searched ebay, iboats, and googles the hell out of it. I think it is going to take someone who knows where to look!
      It is from a 2001 Maxum, btw.
      • #4
        This place has a lot of stainless at good prices.
        http://www.marinepartdepot.com/newststdehi.html
        I think the stainless rail mount would be a good alternative to the plastic piece you are using now.
        1998 Wellcraft Eclipse 24 Cuddy
        Volvo Penta Duo-Prop 7.4L "LK"
        2006 Sun Tracker Party Barge 21
        Mercury 90 4-Stroke FI
        "Common sense is not very common"
        "Failing to prepare is preparing to fail." -- John Wooden
        • #5
          They have changed over the years.
          Same function, Different mounting style.
          Bill, Lorain Ohio
          • #6
            [ATTACH=CONFIG]149304[/ATTACH]
            Given I am on the ocean, the Bimini takes a beating. The thing I like about the nylon mounts is they take some of the stress and the fact they wrap around the frame and are attached with a pin, there is nothing to strip. Net, I am concern about screwing the mount into the aluminum frame and hoping the extreme stress doesn't strip the mounting screws. Anyone with experience with screwing a mount to the aluminum window frame, comments appreciated. I am still looking for the straddle mounts.
            • #7
              These do a full wrap instead of completing the wrap with a pin.
              http://www.********************/p/NAT...unt+Hinge.html
              http://www.********************/mm5/m...ry_Code=240000
              [IMG]http://www.********************/mm5/graphics/600/NAT-11749_lg.jpg[/IMG]
              Southern, NJ, USA
              Currently Boatless
              Date an I/O, but marry an outboard!
              • #8
                And the one that matches yours:
                http://www.duckworksbbs.com/hardware...e-sp/index.htm
                Southern, NJ, USA
                Currently Boatless
                • #9
                  I know what he is talking about. I have them on my annoying bimini which can turn into a camper enclosure. The bimini pole mounts to the windshield and the fabric snaps into the windshield and you attach a strap to a mount on the gunnel. I also have the slant back and the two windows. I did not care for that bimini as it acts more like a parashoot and doesn't give enough protection. I got an iboats standard bimini and love and use that all the time. Though I will see if I can find what you are looking for. If you take up what other suggest you bimini will not mount properly.
                  2000 Maxum 1900SC
                  4.3L Mercrusier w/ Alpha One Gen II
                  • #10
                    [ATTACH=CONFIG]149364[/ATTACH]
                    This looks very close to what we both have.
                    You could always call Brunswick Boats (who owned Maxum) or who ever use to be a dealer for them in the area. They might have some parts laying around. I was able to get non-standard SS ladder made for the Maxum a little over a year ago, from the former dealer. Make sure to ask for: "1705898 CANVAS HINGE,PLASTIC TOP BAR,WHITE"
                    source: http://www.maxumboatparts.com/2001/s...t/mc2.htm#7170
                    It might cost a little more than what this guy suggested, though it will match and you know it will work.
                    -Hostage
                    Edit: Looks like these guys sell it for $2.50: http://westrivermarine.awardspace.co...ts%20parts.htm
                    Also you could call up a Bayliner dealer as many boats owned by Brunswick use similar parts. I think you should be all set with a few sources to follow up, good luck!
                    PS - It is actually called a "convertible top", not a Bimini. This is news to me as well.
                    2000 Maxum 1900SC
                    • #11
                      If you absolutely want an identical part. Cast it yourself.
                      This is a lot easier than you would think.
                      And the results are excellent. (You can mold your hand and take fingerprints from the casting.)
                      Casting resin is really tough stuff. A part your size would withstand a hammer!
                      Bill, Lorain Ohio
                      • #12
                        Thanks all, I found what I need. Hostage pointed me down the right track, West River Marine has bought out a few years back, so finding the right number was a challange, but finally tracked them down. But, the part number you gave allowed me to call into Bayliner who put me in touch with a local company that had the exact replacement.
                        All the best guys!!!
                        • #13
                          Where did you find those U-Shaped Bimini Mounting Bracket???
                          • #14
                            Old and inactive. Please start a new thread.
                            Closed.
                            BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
                            Please, no PM's (Private Messages) regarding boat/engine problems.
                            That is what the forums are for.
                            Only forum/moderator issues will be answered in PM's.
