Re: New drum for cable/pulley steering system...where can i get one?
A friend of mine sat on the steering wheel and snapped it off (only the plastic part). This left the metal ring that normally fits inside the center of the steering wheel attached to the shaft of the drum. I've tried every possible suggestion and can't get the thing off if it meant the end of me.
In the process of trying to get it off, the pin that holds the drum in place (prevents it from going in and out of the dash) broke off. So now the drum is loose in the dash and I can't put a new steering wheel on because of the metal piece that won't come off the shaft. I don't know if any of this made sense but I'm officially stumped aside from replacing the whole drum.
Thanks,
Joe
