Last August while going about 2000 rpm I picked up a submerged tree limb between the prop closest to the stern. The limb was about 5 foot long and that wedged in behind kicker motor. It got jambed in. The out drive came up past the tilt and stopped the boat dead in the water. It cracked the prop and the trim cylinders started leaking. The prop was also spun ( the larger Prop), also seal in front of props leaked oil. When they pulled outdrive the seal leaked oil in the boot by the drive shaft. I put a dial intercater and prop shaft was true. Did any body ever have this happen???
Bill
Bill
