Re: Old Steering system
I'm thinking you have the splashwell mount with the plate bolted to the side of the well. You can re-use the plate and ball if it is still good or you can replace with a complete Teleflex helm and cable. Rack and pinion or rotary--your choice. Small boat like that does not need no feedback system unless you are getting speeds over 60. You will also need the bent stainless steering link from cable to engine.
If your engine does not have tilt tube steering capability, you will need to by a transom mount.
