Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Exhaust Fumes in Boat
  • Exhaust Fumes in Boat
    I just bought a boat with an 1982 80hp Merc outboard and we were out on the weekend and the people in the back couldn't stand the fumes,burning there eyes. Is this normal when putting down the river. There is a hole that I believe was cut for better access to the bottom spark plug that we covered with a sticker but that shouldn't block any exhaust. Any ideas on how to fix this besides selling the boat. Thx
    Re: Exhaust Fumes in Boat
    Are you using an onboard tank or are you using portable tanks?
    2007 Mariah DX212 w/ 2007 Merc 150 Saltwater
    [ATTACH=CONFIG]temp_129201_1408990994699_719[/ATTACH]
    "Knot A Lot"
    Finally...my boat is not the oldest vehicle in my yard!
    ...and there's a prayer in every post for my friend, Sasto...
    • #3
      Depends on how slow you're going, which direction the wind is blowing and what type of oil and the ratio you're using.
      Also, some people are just more "sensitive".
      1980 Sylvan Aluminum 18' Sportster I/O - Mercruiser 140, Honda 7.5 Kicker, Bennett M120 Tabs
      1974 Glastron V-179, Mercruiser 140
      1984 16.5ft. Alumarine Sealark side console with 82 Merc 50
      Manitoba, Canada
      • #4
        We are basically just in gear and putting and it is a big on board tank about 15-20 gallons I would say. Mixing it 50:1. Never had this problem with any other boat we have owned.
        • #5
          If the wind is behind you, it will blow the fumes over you. Try turning downwind or cross wind.
          The exhaust should exit thru the prop and thru the two square holes on the midsection. Any other place should not have exhaust exiting.
          • #6
            All 2 strokes smoke to some extent.
            A motor that is out of tune or running rich from carb issues will make things worse. Keeping the motor well tuned and running synthetic oil will help keep smoke to a minimum
            • #7
              1982: Ah, the smell of a smokey, older 2-stroker. Loved me a good carcinogen back in the day.
              By design, 2-strokers burn oil. If she is getting the right am't of oil, there isn't much to do beyond what dingbat suggests.
              Southern, NJ, USA
              Currently Boatless
              Date an I/O, but marry an outboard!
              • #8
                +2 on the change you mix oil and tuner up.
                home is where we drop anchor
                • #9
                  sit up in the bow.
                  I know of an incident on a boat about 26' with a cuddy and side curtains; they were trolling with the wind behind them and the area inside the covers filled with carbon monoxide.
                  People riding on swim platforms (which you shouldn't do) and tubes at low speed/short rope have had this problem, too
                  A man of constant boat tinkering.
