I pulled off the old packing nut on the rudder shaft, and ordering 1/4 in packing material for it, and the new packing material does not cover all the way to the edge of the nut where the rudder shaft goes through. Will the material compress and "seal" against the rudder shaft as I tighten it down? Or do I need to order a larger packing material?
Thanks
Thanks
