My 15.5' Bass America (aluminum) has the bilge pump (Tsunami 500, small pump) mounted on a block of wood. The wood serves no other purpose. While it works fine here, I would like to mount it lower in the bilge, in the same spot removing the wood.
Tsunami instructions say mount it on a "suitable pad" which they describe as "marine plywood fiberglassed to the hull". Now it's obvious why you wouldn't want to screw it to the hull, but could there be some electrical issue here? Ground? It has a direct ground to the battery.
I could easily make an aluminum bracket that would put it almost as low as possible.
Also, is there any reason I couldn't epoxy or glass it directly to the hull?
Thanks,
John
Thanks,
John
