Picked up an old but new in box Bennett tab system over the winter. It bench tested fine and I am pulling the boat to install the tabs next week. Problem is my ProLine 201 Outboard has very little spare space. The two rear battery compartments on each side of the OB don't have enough flat surface to fit the unit. I noticed the HPU comes with a plastic side mounted bracket with four screws that actually holds it in place. I was thinking of mounting the HPU bracket on the inside of the transom above the port side battery (I have dual battery setup). Would the bracket hold up to the stress of mounting it on a vertical surface only w/o any support from the bottom, sort of hanging in mid-air. It looks like they are designed for that but it seems a lot of weight for just the bracket to hold.. Has anyone mounted theirs this way? Maybe TABMAN is looking ...
