In the past I have sheared-off more screw heads because, I think, of the adhesive sealant. Is there a good method of preparing decking screws for removal? (I say primarily decking because they are the ones most exposed to heat/cold, wet/dry and can be the most ornery to remove)
Thanks
Thanks
