Warning indicator on hour meter?
brad614
I have a 2004 Larson Cabrio 240 with the Volvo-Penta 5.7 setup. There is an hour meter built into the bottom of the tach. On the left side of that is a flashing icon that looks kind of like an hour glass. Is this some type of warning? If so, is there a way to reset it?IMAG0154.jpg
Cheetah 210es
Re: Warning indicator on hour meter?
Its not a warning, it's just letting you know its working.
sschefer
Exactly. Think of it as a "Key On" alert. The hour meter runs when the key is in the run position. The engine doesn't need to be started. This is just trying to tell you to turn the key off unless your actually running the motor.
Fireman431
It's telling you that at 240 hours, the boat self destructs....:D
Philster
Don't call me a grammar Nazi, but you have a comma splice in your post, Fireman431.
:D
