dereck_coons
- Mar 13, 2011
- 20
Trying to Plumb my boats built in bait well. Bait well is located under front seat directly in front of the center console I have installed a 800gph rule pump and ran a 1" line from the pump to the water in nozzle. The problem is where to run the drain line. Should the drain be located in transom above water line or is it better to try to run it through the side above the wateline? Getting to the transom is a whole lot easier than going through the side because of floor stringers and built in rod storage that has no access so I would have to cut a port into the fiberglass to install in the side? Any Ideas? Thanks
