riponfisherman
- Jul 24, 2010
- 7
Hello, I recently purchased a 1992 Ebbtide Dynatrak bass boat with a 150hp Yamaha engine. The boat is in excellent condition and is currently water ready. This is my first fiberglass bass boat, I upgraded to it from a Bluefin Spectrum 17ft with a 50hp force. I am decently mechanical and I did a partial restoration of my old boat, but I am not a genius with this stuff by any means and I have a couple of questions about some stuff.
1) The dash has digital gauges that light up and activate when the key is turned on, is there any way I can check to see if the speedo part works without it being in the water?
2) How exactly do the live wells work?...The ones in my old boat had a pretty straightforward fill/drain process, but they were different than the ones in the new boat.
3) There is bow mounted Eagle Fishfinder on the bow that has the transducer on the trolling motor but there is no finder at the console and I would like to put a GPS/Fishfinder combo there, ive looked around online for some but I would really like some advice has to what a good cheap one would be. I am a college student and its not like im broke or even close to it, but I really dont want to plop down a ton of money on one at this point.
4) Is it worth it to get an onboard bank charging system? The boat has 3 batteries, im assuming 2 for the trolling motor/finder and one for starting.
5) Any other tips/advice that anyone would have would be greatly appreciated.
I will post some pics of it as well
Thank you
Thank you
