Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How do you stop water from filling up your boat cover?
  • How do you stop water from filling up your boat cover?
    I have a 1990 Regal 233 Xl Ambassador Cabin Cruiser. I store it outside and cover it completely with a good water proof boat cover. The cover goes around the 2' tall pulpit / bow rails in the front and over the rear deck rails. I used 2 inflatable exercise balls in the front to form a inverted Vee and I used an adjustable pole in the rear deck. Proberm is, is when the cover gets wet it forms pockets and when it rains hard or snows it forms very deep pockets. I had to go out several times last winter and bucket the snow and water off. I was thinking this year to use 1/4" plywood over the bow rails and stick 2x4's underneath for support and the same for rear deck, this way the cover would not dip. So far, water has not entered the boat, the cover is very flexible and can hold large pockets of water. I strap the cover with 6 adjustable straps on each side, 2 on the bow and 2 on the transom, and adjust the frequently.
    Any suggestion on what to do??????????
    Thank you
    Re: How do you stop water from filling up your boat cover?
    Keep it in a barn, or shrink wrap it, or use more internal supports.
    I consider overkill a job well done... plus a little extra.
    There's as many ways to do something as there is people to tell you how to do it... but not all of them are the right way.
    The drinking and debauchery will continue until morale improves... and maybe for a little while after.
    • #3
      IMO best thing to do is built a simple 2x4 ridge pole with supports that rest on the floor of the boat running full length. Couple things that are important, make sure the base of the support poles have a piece of plywood (roughly 8x8 or larger) screwed to the bottom to distribute the weight (a piece of carpet under the ply is a good idea as well) and the peak or height of the ridge pole needs to be higher than the windshield and provide a good pitch side to side to shed the snow.
      To hold the ridge pole in place use some light weight rope or fiberglass strapping (like what's used when they shrink wrap a boat) and tie the pole side to side looping over and around the pole so it doesn't slip... Secure the cover nice and tight and you'll be good to go.. Kinda hard to explain, but here's a link showing some pics of a boat I framed before shrink wrapping. Not the best pics, but hopefully between the pics and my description you can make heads or tails of it.. http://www.millerboatworks.com/?110560000000
      Hope this helps!
      ~BWT
      You might fall down on your face, roll the dice and have some faith!
      • #4
        I used 4" PVC drain pipe with 2 90* elbows and built a center ridge support to go under the cover for my cruiser. $15 at a home improvement store, Problem solved.
        1989 21' Eliminator Daytona - Indmar 454
        1974 Sleek Craft Rebel - Pontiac 400
        1976 Sleek Craft Ambassador
        • #5
          Here is what I used. Some 3/4" PVC and some elbows
          1986 Carlson CVX-18 Restoration
          1995 Sea Ray 220 Signature Deck and Stringer Restoration (SPLASHED!!!)
          1981 Glastron SX-190 Rotten Transom Replacement and Re-power! (Splashed and SOLD)
          Follow !
          • #6
            I did the same thing and added cheap blue poly tarp over the top of the cover, secured with bungies. The tarp stretches a bit tighter & provides a slick surface.
            • #7
              They were all great ideals, but with a ridge beam 2x4 at the bow, the length from pulpit bow rail to the top of the windshield is 16' horizontal. I would need to get the 2x4 angled up to get to the height of the window. On that angle towards the window, what does the end of the beam rest on. It just can't be suspended in the air, because the weight of water or snow would pull it down. I understand about 2x4 post on wide platforms for balance, but not on how to continuie the V effect towards the window. However, I think I can do the PVC on the deck plat form.
              Here's a picture of the boat so that you guy's can get a better understanding.
              • #8
                How do you pitch your boat cover to keep water from pooling
                I had started this tread on the Restoration page, I had some good ideas but need more.
                I have a 1990 Regal 233 Xl Ambassador Cabin Cruiser. I store it outside and cover it completely with a good water proof boat cover. The cover goes around the 2' tall pulpit / bow rails in the front and over the rear deck rails. I used 2 inflatable exercise balls in the front to form a inverted Vee and I used an adjustable pole in the rear deck. Problem is, is when the cover gets wet it forms pockets and when it rains hard or snows it forms very deep pockets. I had to go out several times last winter and bucket the snow and water off. I was thinking this year to use 1/4" plywood over the bow rails and stick 2x4's underneath for support and the same for rear deck, this way the cover would not dip. Last year water did not entered the boat, the cover is very flexible and can hold large pockets of water. I strap the cover with 6 adjustable straps on each side, 2on the bow and 2 on the transom, and adjust them frequently.
                From the pulpit to the windshield is about 16 lf, the boat is 9.5 ft wide, almost 24.5 ft in total length.
                • #9
                  Re: How do you pitch your boat cover to keep water from pooling
                  Block the jockey wheel up off the ground so the water slopes off to the rear?
                  • #10
                    go to a shop that sells shrink wrap....and ask for post ends.....
                    kinda a flower looking thingy that attaches to the top of a 2x4......stick the 2x4 under the tarp and cut to length
                    The Hull Extension Thread
                    great info on all aspects on boat building with detailed information.
                    http://forums.iboats.com/showthread.php?t=234392
                    IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
                    IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
                    November 29 2010 RIP
                    • #11
                      http://www.bigshrink.com/Straps-Supports_c_12.html
                      Click image for larger version
                      Kevin
                      Originally posted by Tinnie
                      But, where are the reevets?
                      1981 Wellcraft V-20 CC Fisherman (FREE BOAT)
                      1989 Wellcraft Monte Carlo 28(Build thread here)
                      1992 Hotsports Jet'n'Cat Yam 701 WR3 drivetrain "SS George Washington"
                      90's Yamaha WRIII and a pair of 95 Kawasaki ZXI-900's
                      Fresh clean cheap oil is better then old dirty expensive oil any day
                      sigpic
                      • #12
                        I like the ideal on how the shrink wrap company used the 2x4 post and string method, but I am not using shrink wrap, I'm using a full wrap around boat cover.
                        I live in the midwest, not in a populated area so my resources are scarce.
                        • #13
                          the same method works for your boat cover...... Last I checked, UPS delivers to the midwest also..... If you want to cheap out on it use some bucket lids. Cut a few slots and staple them to the 2x4's.... the strapping they use is important... flat to staple and doesn't stretch
                          You could use rope and ratchet straps to tension it but it's more of a pain
                          Kevin
                          sigpic
                          • #14
                            2x4 = yuck.
                            Get some PVC piping. Possibilities are endless.
                            Checkmate 2400BRX/Optimax 300xs
                            Alumacraft 17 w/ Merc 40 4S
                            Date an I/O, but marry an outboard!
                            • #15
                              A good skyhook otta hold that 2x4 up lol
                              1996 bayliner capri 1950 cl 3.0 lx mercruiser alpha1 gen2 escort trailer my rebuild(in progress) http://forums.iboats.com/showthread.php?t=542448
                              Back to Top
