Re: Fiberglass restoration
hi.....welcome to iboats.
a 3m rubbing compound. will remove oxidization...then the finish needs to be buffed with a proper gellcoat polish.....i use farecla, this will keep the shine on your boat for many seasons.
some people like to go the re surface route....buy wet sanding at 800, but a good rubbing compound will work...
i use an industrial polisher.....a makita. but harbour freight has a vari speed sander polisher for about 40 bux
