Re: Key West Gelcoat Question
cpt dale, I have a Key West (15' Explorer). I picked it up very used for $1600 B/M/T that was back in 2006. I have tourtured that boat! drilled dozens of holes in it, ran it full speed on to a mud bar that was covered by an inch of water (didn't even see the bar) fish the back country with it along with the reef 6 miles off shore if the water is 2'or less. let me tell you they are tough boats! the hill is pretty thick glass and the gel coat seems to be normal thickness and even a little thick in areas. 100% form filled even more foam in this little boat than in a Carolina Skiff. I replaced the fuel vent which was located just below the rub rail and it was all foam around the hose every space between the hull/deck and sides is foam you couldn't sink it if you wanted to. I had some issues with a bait well pick-up that came loose allowing water to enter the boat and soaked the inside of the transom, every thing seemed to dry out ok no water log and no soft spots. the merc 60hp that is on it has since died and the rig is just sitting behind my house. i got a nother boat now 17.7' enterprise, but i love that little key west so much i cant get rid of it. It is in real rough shape now (internal fuel tank got a hole in it so had to cut the deck to get it out), but it has been such a great little boat i will strip it down to bare hull and rebuild her one day. it drafts about 5" and is just light enough that if you get stuck you can lift and turn the bow out to deeper water, it is a work out to push but have never been stranded because of not being able to get her to deeper water. my only complaint with the one i have and also the 22' i tried out is they are wet boats! the slightest ripple in the water and you are going to catch the spray!
