4winnsskipper
- May 9, 2007
- 204
Greetings, im looking into 27' sea ray amberjacks to purchase and im seeing the same model boat with twin 4 cylinders, twin 6's, twin 8's (5.0 and 5.7s). With such a wide range of power im wondering a couple of things. The boat will be used PRIMARILY for trolling (2.0mph) about 1 - 5 miles offshore, about 2 to 4 times a month. SO i'd estimate about 10-20 hours use a month.
a) what is the real world gas usage difference here? I know you can't just say an exact amount as it varies but im wondering conditions being equal, will the twin 5.0 v8s use that much more? Im trying to figure out how much more throttle the 4's will need to go the same speed and plane... just looking for input here...
b) anything i should look for in both? like power steerring on both motors or is just one ok? i notice most have it on just one motor
c) being used 20 hours a month or so will my pocket see much of a difference between running out 2-3 miles offshore , trolling and coming back - montlhly expense wise between twin 6's and twin 8's? Again im taking in account the amount of work motors will need to do since the v8's will see less strain whereas the 4 cylinders may need to be at full song to even get on plane?
any advice is appreciated.
