Probably an easy question:
I have a Tempo 6 gallon gas tank for my 16' Lowe. When I unhook the tank from the motor, it leaks out the spout (and continues to even after setting a while). Is there something I'm doing wrong or is this a bad tank? Is to much pressure built up? I unscrewed the cap and let the air out of the tank.
Thanks for your help
