Evinrude_Enthusiast
- Aug 11, 2011
- 2
Fellow Boating Enthusiasts,
I recently acquired, (came into?), a 1964 Evinrude Sport 16' motor boat. To be honest, my boating experience does not go back quite that far and I feel like a fish out of water dealing with this boat. I hope to find someone on this forum that would have a better idea as to what it is worth.
A little bit of information about the boat (I apologize for the bullet points, but it makes it easier to read):
- The boat is in Excellent shape. It was kept in a garage and maintained by a local mechanic (former Evinrude Tech). It has less than 50 hours of time on the water (family is the original owner) and does not have any noticeable sun, water, or even transport damage to the hull.
-The boat is entirely original. 1964 Evinrude 75 HP V4 2 stroke motor (replaced cooling pump, a few seals (thanks mice), and spark plugs this summer). The electronics were replaced last year after I discovered that mice chewed through the throttle, ignition, and (F/R) lines. The motor / components are in perfect working order and speed, compass, and battery gauge still work. It runs surprisingly well according to the mechanic (although it is said you could run another boat off of the exhaust from the engine).
- The Hull is entirely intact and does not have any repair work (never required any). Original seats, steering wheel, deck, paint, etc. This boat is 100% the same boat purchased 47 years ago.
- Original Trailer, with no noticeable marks or damage from loading/unloading.
We were considering keeping the boat as a "once-a-summer" treat, but the mechanic commented that it could have value to a collector. That is why I am turning to yall. So please, someone out there, if you have any idea what this boat is worth let me know. I can answer most questions and want to ensure that taking the boat out on the water as nothing more than a boating enthusiast is not a bad life choice. I guess what I am getting at is that I do not have enough time to use the boat as often as it should be used, so if it is worth something to someone I am not against parting with it. Thank you for your time!
