Re: Telflex steering cable (rack system) Question
There's no way to remove the cable from the sleeve on a Teleflex Rack. I just put a new one in my boat, and while I could move it by hand off the helm, it wasn't easy. The Rack itself doesn't disassemble so if you can hook that back up to the helm and use the wheel to move the cable that would probably be easiest.
If it won't move at all, I might consider replacing it. Especially if you've already got the cable out of the boat, I'd take the opportunity. Because you can't get in the cable, you can't really be sure what's causing the hangup.
