brendella1
- Jun 19, 2011
- 1
I recently acquired a 1991 Ski Brendella Super Comp ( to go along with my 1999 Ski Nautique).
After replacing the motor and going through the process of aligning the prop shaft I noticed that the rudder centerline does not align with the prop shaft.
The rudder center pivot is off centered from the prop shaft by approximately 1-1/2"- 2". Obvious, it is designed that way, although I have never heard of this type of offset on ski boats is it common?
