I recently replaced all my baitwell and bilge pumps on a 2007 Ranger Ghost. The bilge pump comes with a separate Rule mechanical float switch. I removed the old one and replace the new switch making sure the wiring was exactly the same. I tested the pump and everything worked fine for a month or so. Then suddenly, I saw a blinking red light on instrumentation panel for the bilge. According to Ranger, that indicates there's something wrong with the pump. The pump works fine but it will not automatically kick on when water floats the switch.
Is there a normally a fuse (in line or breaker) associated with the float switch? Does the Rule bilge pump have a separate fuse or breaker? Any sugestions on how to fix this absent of having to take it to a Ranger dealer or repair facility?
