Re: Mounting Bimini Top
^^100%...they hardly ever break off where you can get a hold of them.... pre-start the screw by hand... if it gets to tight, back it out and use the next larger drill bit.
I would take the advice from ajgraz... thru-bolting makes a stronger mount, even better with an aluminum backing plate.
