Anyone have any experience on replacing a livewell pump on a 2007 or recent model of a Tracker Pro or similar Basstracker boat. It appears that in order to replace the pump the gas tank would have to be removed. Is that correct, and if so, is there an alternative? Was looking at the thru-hull livewell pump, but do not know what it entails as far as replacing the original pump hiding behind the gas tank with no room to maneuver or even put your hand in there.
Any help will be greatly appreciated. Bill
