Re: Question about Cape Craft / Key Largo Boats
Bob - I have a 17 ft '99 Key Largo (probably pulled from the same mold) and it has a 35 gallon plastic tank. Like didit said, there should be an access hatch in the floor right over the fuel sending unit. When I opened mine up mine, I even found the original tank sticker still there... made by 'Inca Products'.
didit - The "150" model is 15'3", max hp is 60, 4 people, and approx weight of 875 lb. if you have the "160" model, the length is 15'10", max HP is 75, 4 people, and approx weight of 975 lb. Either one sound like yours?
I believe the data-plate is required.
I have the same contact numbers for the factory, but you might try "Fisherman's Boat Group" (305.634.5754) in Miami for help. They're a dealer and should still be in business,... I've personally given them enough $$$ to stay afloat (pun intended) for a long time to come!
HTH
