15hpevinrude
- Jul 3, 2010
- 33
I purchased a new 14ft Discovery Voyager Boat over the winter, and finally got it in the water. The original livewell pump was leaking because the hose barb was cracked. I replaced it with the same pump SeaSense 800gph through hull pump. It runs but does not pump water. The hoses are also new. I replaced them over the winter, with new hoses. I am sure the feed hose is not plugged. I can screw a garden hose to the threaded portion that sticks out past the hull, and it pumps water into the livewell past the pump no problem. The pump is running, but nothing pumps? any ideas?
