Re: Lenco high torque motor that goes inside the trim tab??
In same boat ,kinda AGAIN.I replaced my actuator not many HOURS ago,it has a short ,due to water intrusion.Last time I replaced it,I too looked for the motor you describe,I could not find one,if you happen too please shoot me a message.That all said.I got my Irish up with Lenco last time I had trouble.I was TOLD,the actuator was a SEALED unit with NO replaceable parts inside,the only remedy was actuator replacement.I got into it deep.They claim its sealed for life,however ,mine leaked ,the leak caused motor to fry.I was told ,it was non serviceable.Around and around i went.Bottom line,I needed boat fixed ASAP ,bought a NEW one ,now I need to do it again.My opinion of lenco,THEY SUCK.I had many a boat ,worked on many a boat with BENNETS and can tell you this,they bend over backwards to help fix your unit and often replace the problem at low if any cost.Im actually searching this site for my last Lenco complaint,was long ago,but certainly actuator should not have broke .i base that on the starboard ond still working and its original.i believe they do have issues with the so called seal.I live in Fl.Keys and know a few guys that had the problem.Good luck,keep me informed if you learn anything,ditto on my end. Mike
