Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
Trim tab leaks
  • Trim tab leaks
    Is this fixable? When I put the tabs in full down position and hold the momentary switches, oil runs out of both pistons. Click image for larger version
    1999 Bayliner 2655 Ciera 5.7L BIII
    1996 Skeeter DV1850 Mariner 175HP Mariner 9.9HP
    1975 Lund Aluminum Mercury 25HP
    sigpic
    Re: Trim tab leaks
    You can order replacement cylinders/pistons from Bennett. Totally fixable.
    Torque gets you there. Horsepower gets you there in time for dinner.
    • #3
      Re: Trim tab leaks
      From the website, it appears that I will need to purchase the "Actuator piston with O-ring, Part #A1109. How do I know mine are Bennett brand and the correct model?
      sigpic
      • #4
        Re: Trim tab leaks
        you might also consider taking one apart..... should only take a couple minutes..... orings can often be had at a local hydraulic shop for pennies
        Kevin
        Originally posted by Tinnie
        But, where are the reevets?
        1981 Wellcraft V-20 CC Fisherman (FREE BOAT)
        1989 Wellcraft Monte Carlo 28(Build thread here)
        1992 Hotsports Jet'n'Cat Yam 701 WR3 drivetrain "SS George Washington"
        90's Yamaha WRIII and a pair of 95 Kawasaki ZXI-900's
        Fresh clean cheap oil is better then old dirty expensive oil any day
        sigpic
        • #5
          Re: Trim tab leaks
          They don't look like Bennetts.
          I've never seen Bennett use external oil lines on their cylinders. They look like Insta-Trim, Boat lever tabs to me.
          http://www.insta-trim.com/main.html
          • #6
            Re: Trim tab leaks
            Good catch ^^^^^^ I have a note into Bennett and I think they have conversion kits for Boat Leveler. Tabman is pretty good about responding.
            • #7
              Re: Trim tab leaks
              Yep. That big red bottle rings a bell, as I just spent the better part of a day with my head down in the hole. I'll wait to hear from Tab man. Thanks all.
              sigpic
              • #8
                Re: Trim tab leaks
                Here's an old, but better view.
                sigpic
                • #9
                  Re: Trim tab leaks
                  Sorry for the delay in responding, this one got in under my radar.
                  Those are indeed Boat Leveler brant Trim Tabs, the company that makes them is Insta Trim. They are in Saint Louis, and their website is http://www.insta-trim.com Their phone number is 314-385-7470 or 800-386-7470.
                  They are a good company and nice folks. We do make a conversion kit but I would contact them and see what they have to say.
                  I hope this is helpful.
                  Tom McGow
                  Bennett Marine
                  sigpic To learn more, like us on Facebook https://www.facebook.com/bennettmarine
                  • #10
                    Re: Trim tab leaks
                    Delay, what delay? We so appreciate the help this forum and what the experts provide. I'll get in contact with the insta trim folks. Thanks.
                    sigpic
