eastont
- Dec 16, 2008
- 511
Does anyone have any knowledge about this. I am hoping to use it to check the fuel consumption between the port and starboard engines.
As I have mentioned before, the port used twice the fuel as the port and after much work, valve job etc., it remained. Then I swapped carbs and it got a lot closer, but I now don't know if as a result the starboard engine is using more fuel.
My hope is to put it on the starboard engine, then swap carbs and see if the usage changes.
Thanks
Thanks
