I have a switch for a "washdown", but can't seem to locate the hose bib anywhere on the boat. Does anyone out there know where I hook the hose? Thanks for your help, Mike
With a raw water washdown system you have an intake. Look for a thru hull or a scoop type intake below the water line at the rear of the boat. If you don't find an intake, you don't have a pump. If you have an intake, follow the intake to the pump then the pump to the outlet.
