kanada
- Mar 15, 2011
- 76
Hi gang,
Rack steering on my 78 Aristocraft 9teen is so hard, that it is unsafe to boat.
Ordered replacement rack cable, but will have to send it back, since bolt pattern and teeth are different - will not fit existing pinion gear.
This means getting the whole new helm and cable.
engine is mercuiser 470, btw.
Did some googling and looks like the rotary is better choice, since it provides smoother and easier steering. Is that so?
I really liked the Uflex Rotech gear setup - makes sense for my engineer brain.
Now the question - will the cable length be the same for rotary as it is for rack and pinion?
Thank you for your wisdom, advice, random thought, opinions, instructional videos, etc.
Engine connection - looks like standard guide tube right?
This is disassembled rack end - old style with bolts that u can take apart - new unfitting replacement is all rivets (going back to the seller).
KaNaDa
KaNaDa
