Livewell Pump Question - Johnson Pump
fishguy13
Just finished completely redoing a 14' alumacraft into a fishing boat. I installed a livewell and pump. My question is, why won't the pump operate now. I didn't level the pump. I flush mounted it to the hull which has a slight angle on it. Am I getting an airlock due to the downward angle intake now? It is very slight. Only 10 degrees or so. It is a brand new pump from Cabelas. It is wired correctly. It did work one day after I took my paddle and tried to pop the bubble out while in the water. The second time out, I couldn't pop the bubble. I didn't try as hard though.... Any help would be great. Thanks in advance!
