Hi,
I bought a Moeller 10 um filter/water separator to install on my 99 Skeeter ZX185
with 150 Yamaha Vmax
First attempt I made a block, inserted 3/8 carriage bolts and epoxied the block to the plastic fuel tank. Competely degreased the tank and used the correct type epoxy, however it came off the first trip out.
Would really like to know how some of you mounted your filter assemblies. Such limited room/options on this boat I am having a hard time thinking of a solution that will last due to the heavy weight of the Moeller.
Thanks for the help,
