Store Links Mobile - Shop Now
No announcement yet.
boat fender opinions please
  • boat fender opinions please
    hey all i have an old 18 foot stingray open bow boat. im looking for opinions and preferences from owners of the same size boat(give or take a foot) on what size, style, and amount of boat fenders you use. i do tie up to a rough dock for at lease 30 minute every boat trip.
    Re: boat fender opinions please
    Check these out: http://www.iboats.com/Kwik-Tek-Hull-...-view_id.38994 I have a pair of them. Awesome!!! They fold up, neatly into rectangular cushions.
    Safe and happy boating always!!!,
    Veritas Honus
    1992 Chaparral 2050 SLC: 205HP 4.3L Yamaha I/O
    ShoreLand'r tandem axle trailer
    T/V: 2001 Dodge Ram 1500Sport 5.9L 4X4 Off Road Package Dana 410 rear
    Fear is only a state of mind. Gravity is a fact of life...
    No fall, however high, ever hurt anyone... It's that sudden stop at the end...
    • #3
      how thick are those pads?
      • #4
        The pads are 2 1/2" very dense foam rubber. Each pad is on top of another inch of the same dense foam. It's all tightly sheathed in a very tough and resiliant nylon reinforced vinyl covering. I have two for rafting up and to put on the undocked side of the boat, when in public areas, just in case. I like them much more than traditional fenders. They give a lot more protection.
        Veritas Honus
        • #5
          You didn't mention if $ was a factor, but if you're looking to protect on the cheap, my solution was Wally World. I bought six of their bigger of two sizes 6"x20" inflatable tube fenders for $9.99 each and rigged 2 on either side of my 18' bowrider. I've never needed to deploy all 6 because I always dock in protected harbors/marinas so the other two get used for water toys when we anchor in coves to swim. They make great flotation devices for paddling around on them, or throwing like footballs to the kids! Best price anywhere in my opinion! Also, as an aid to keep them clean and lasting longer against rough docks here's a tip: Find a pair of under-appreciated jeans and cut the legs off at the knees. Slip the fender inside and inflate it until it expands against the denim to snug it up, or failing that, sew up the open ends so the fender can't escape. The denim adds a layer of protection to the vinyl fender, and they don't squeak when rubbing up against a metal dock or pier either. YMMV!
          • #6
            The blue jean legs are a great idea. Very resourcful thinking.
            Veritas Honus
            • #7
              Nice....real nice!
              BOAT=Best Of All Times
              "Everyday above ground is a good day"
              Winterization=sneekers, jeans and a sweater.
              Same Ship.....Different Day.
              • #8
                Taylor made fenders have a life time guaranty
                • #9
                  Taylor Made 20" fenders are the only way to go. Buy at least the 5" ones. On my Stingray I bought 2 extra pairs of deck cleats that matched the ones already on the boat, and mounted 2 on each side midships between the originals. So, use 4 fenders on a side and when you aren't docked you have extra cleats to tie tubes, etc.
                  2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
                  2015 Yamaha FX Cruiser HO
                  1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
                  1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
                  1960 Mulray 100 Dinghy, equipped with Beaver Oars
                  1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
                  68 Outboards: 1919-2017, representing 11 manufacturers
                  Member ACBS, LBOA, AOMCI
                  • #10
                    I've used the Hull-hugr fenders for four seasons and they are a joy to have. They store easily, act as cushions when my kids want to sit on the floor, and work with almost any kind of dock. Mine have the joint about 1/4 way down. The covering slides on most surfaces, instead of sticking so they stay between the boat and dock better than a plastic fender that's not in a sleeve.
                    Where they don't work as well is if you tie up with another boat or if the edges of a 'rough' dock are not even and some boards stick out a couple inches from others.
                    Mine are the small size rather than the large panel, about 6"X24"
                    • #11
                      I have also used the Hull-hugr fenders when I tie up to my slip. I have also mounted the ones they have to the dock. This gives you two layers of protection. I have had very good luck doing this and have not received any dock rash. When in the slip I also use spring lines to keep the boat from moving forward or backwards. The Hull-hugrs are about as good as it get imho.
                      • #12
                        You sold me on these. I'm going to buy a pair for my boat.
                        2011 Stingray 215LR - clocked at 55.2 mph
                        2010 Ford Sport Trac V-8 Tow Vehicle
