Re: Jabsco PAR-Max 5 Washdown Pump
It's a constant velocity pump meant for sustained use, not like a bilge pump meant to move high volume for a short time. You will have moderate volume with decent pressure as long as there aren't too many fittings in line or a long run from the pump to the nozzle. Friction loss accumulates quickly in small pumps.
