Re: Removing Bottom Paint
this has been discussed often. The general consensus, if such a thing is possible, is that it is difficult and expensive to remove correctly, and dangerous and difficult to do yourself, and then you have to treat the effects to the surface of the hull before you repaint--in other words you can't remove without having to repaint (based on the assumption that you are removing for cosmetic reasons, and therefore want a cosmetic result).
If you insist, soda blasting is the preferred method.
Because it is difficult and serves no function, many advocate leaving it alone--no one sees the bottom and who cares anyway--or if you must, painting over it with "regular" paint.
You don't say what size boat you have, but if you don't keep it in the water we'd assume it's going on a trailer (although around here there are 30' boats on lifts).
Painting a bottom on a trailer is a pain. I'd rather spend the time and money in the boat, than under it.
