Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
what kind of carpet adhesive to use?
  • what kind of carpet adhesive to use?
    I'm replacing the carpet in my roundabout and was using the automotive carpet/trim adhesive but after the carpet got wet (areas already laid down and glued) it came loose
    what kind of waterproof carpet adhesive do most people use or should I just staple the carpet to the floor and use the adhesive on the sides where it wont really get wet?
    Re: what kind of carpet adhesive to use?
    Most use contact cement or a quality spray glue. Look for one that is water resistant.
    When will people learn that impellers require regular
    replacement and are not drive it till it pukes items?
    1984 Regal Medallion 195
    3.8 V-6 with the dreaded
    OMC Stringer Drive.
    2003 Avalanche w/Hypertech
    If it ain't fixable - don't break it!
    • #3
      contact cement like used on counter tops? just roll it on, let it flash, and lay down the carpet?
      • #4
        I used the indoor outdoor adhesive sold at Home Depot and it worked just fine.
        This is a great link to boat specifications http://boatspecs.iboats.com/
        Please, shop iboats first!!
        • #5
          yes.....use the right tool for the job.......indoor /out door carpet adhesive with the proper notched trowel for the appllication....
          however.....if you have gellcoated your deck......you can put an edging around your carpet perimeter and then use velcrow......you will have a home made snap in carpet
          The Hull Extension Thread
          great info on all aspects on boat building with detailed information.
          http://forums.iboats.com/showthread.php?t=234392
          IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
          IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
          November 29 2010 RIP
          • #6
            I have redone a boat (Fishing boats) 1 a year for 11 years now and I found FlorCraft Premium adhesive the best. One boat was a neighbors 10 years ago, its yet just fine faded but glued.It sits out through the minnesota winters covered.I have now started useing DecoDot vinyl and I have mine done with the vinyl and same adhesive 3 years old and so far so good.
            • #7
              USE a resporator with these cements PLEASE !!..dont be there alone either..( 35 dollar respo can save your life ).
              Nasty stuff man..
              YD.
              Do your best and caulk the rest
