Re: homemade jet boat rudder at no cost
since those stick out at an angle, you will also have an impact on trim... Unless I'm mistaken, that is a sportjet 90/95/120 pump, which had a habit of being a little nose heavy already on their factory thrust angle... Just something to be aware of the first time out. Too much lift in the back of a small jet boat means the front end will plant and turn violently on you! (first time I put smarttabs on my little Sj 95 boat, it turned off the front at speed without warning and nearly ejected the passenger.)
