Re: 14ft Shakespeare Clubman
OH HO! So it is a little go-fast hull! You will have a lot of fun with her.
On my 14 footer I have had a couple of engines ranging from a light 60HP at 165 lbs (45 MPH), to the 125 at about 275 lbs (60 MPH). That was about 50 Kg difference. I found that the extra engine weight did not affect performance at speed so much as the attitude when sitting at rest. Therefore, I believe that you will need to position the tank and battery to help adjust the ATTITUDE of the boat when running, not to offset the weight of the engine. With so much power on a light hull, the stern weight should not even cause any problem getting on plane. When you nail the throttle it should just bounce up onto plane in a couple of seconds.
I think that you will not be happy with a smaller fuel cell. I originally had a 9 gallon (about 35 liter) tank and with the 125 turning 5900 RPM, it lasted less than an hour. That's why I went to the larger tank. Your 115 "Tower of Power" will probably use a similar amount of fuel.
If that were my boat, I would first experiment with weight distribution to get it to ride correctly on the water--high and "loose." Then I would experiment with props, and finally, engine height on the transom. I would not bother with aluminum props at all, only stainless. The performance is way better, and with the Merc, you will have a lot of choice and even a few racing props. On my Force 125 I am running a New Old Stock Chrysler 12 X 21 fully cupped stainless cleaver prop. It lets the engine rev up, can be run high, and made a big difference in top speed.
I also think that correctly set-up, your engine and hull should reach or exceed 60 MPH (96KmH). It should be a lot of fun.
Last word of advice: Install a kill switch and always wear a PFD while running the boat. Good insurance at the speeds you will reach.
