Re: Recycle Pump For Livewell
This is a fresh water pump or a recycle pump, they are different.
If ti si a fresh water fill pump it is as Fireman sadi at the bottom of the transom, just look at the back of the baot and it should be connected to the lowest hole.
They are notoriously hard to get to in the bilge so limber up first.
A recycle pump recycles the water in the livewell to oxidize it during towing adn that pump would be inn or connected directly to the live well, mine is inside the livewell connected directly to an aerator.
