Re: Anchor line length?
I've always wondered why the advice and formulas bother to mention freeboard--whether you add 3' to 100' or 700' makes no practical difference. For a 40' tall freighter, maybe. Or am I missing something?
It is not 3' but 21' you add on a 7:1 with a 3' freeboad. You add the freeboad X scope to keep the angle of the line what the scope is. So to have a scope of 7:1 in 10' of water you need 70' of line, that is if measured at the surface of the water. But if you have 3' of freeboad, now the line is raise and additional 3' and thus changing the angle to less then 7:1, (By the way, 7:1 is the scope with strongest practical holding power, 10:1 has the most holding power). To correct that you need to add 3' (freeboard) X 7(scope)= 21 extra feet of line to correct that.
Reality, the higher your freeboard the greater the angle change. 3' freeboard (most cruisers have this unless really big) will not make much of a change to the scope, especially if it is 7:1 which is a shallowest of the angles. But mathematically it does make difference so those of us who know it state it. I just add the 9' (3:1), 15' (5:1) or 21' (7:1) because I know but that is me (I have a 3' freeboard).
I think having enough chain is way more important in setting and maintaining an anchorage than adding the freeboard on with our small recreation boats.
