Re: Marine Head Question
ha thanks fellas, im going to take is semi apart this weekend. I believe i will have to get a kit to reseal. as i go up and down with the manual pump i have no pressure what so ever. ill let you know, thanks for the help.
You are talking about a problem with the head, not the macerator, right?
It's a raw water flush, manual head, right?
The seacock is open and there's nothing clogging the hose between the seacock and the head?
Did it work fine one day and then not the next or has it been gradually getting worse?
Suggestions:
1. Get the rebuild kit before you try to take it apart. That way, you will have the instructions and the parts you will need.
2. Remove the head from the boat to work on it. Just a couple bolts and a couple hoses. It's far easier to work on it on a workbench or table than in a crowded compartment.
